General Category => General Discussion => Topic started by: Joel on November 06, 2014, 08:43:05 PM
Hello, was curious if anybody has a chain case cover gasket #050909. Also needing the plastic spindle bushings(4) #090722. I have tried the 1981 drifter spindle bushings but they are a different size. Any help would be appreciated. Thank you Joel
I've found if I use the 1980 Drifter parts manual numbers for searching I've had better luck. They used a lot of the same parts on the 1980. 92055-3505 is from the 1980 Drifter parts manual. The 050909 is a Sno-Jet number that Kawasaki used in the 1979 parts manual. I bought one off Ebay a couple months ago. Here is a link:
http://www.ebay.com/itm/like/151323911852?item=151323911852&ttle=Kawasaki+Drifter+Chain+Case+O-ring+New+Old+Stock+92055-3505+Genuine+Kawasaki&vectorid=229466&tc=US
Thanks ,I did find a gasket in my stash after looking at the updated parts #. But still looking for the spindle bushings #92028-3518 if anyone has any. Thank you Joel
The spindle bushings are meant to have a little play in them. How bad are yours?
I have one broken one, so I figured I would replace them all. I did find some , now just need them shipped. Joel
Joel, where did you find the spindle bushings? I'm in need of two of them for my 1979 340 Drifter.
