Site News => Discussion & Help => Topic started by: tonyjd on November 16, 2017, 06:22:43 PM
Hi, can anyone tell me what the factory needle clip setting is on a 4/6? I noticed I have 1 carb set 2nd from the top and 1 2nd from the bottom. always fun starting from scratch without a good starting point!
Your carbs should be marked 36/90, main jet = 130, pilot jet = 35, power jet = 120 RRT ( round reverse type ) , jet needle = 6 DH7-3 ( not completely sure but I think the 3 means 3rd groove ) , needle jet = P9 (159), air screw setting = 1 1/2 turns out and idle screw setting 7 turns with and idle speed of 2500 rpms.
Thank you, I figured the 3rd Grove would be a good strating point from there run it and check the plugs often until all looks good. LET IT SNOW.
