Tech Information > Tips and Tricks
Thrush Washer Question
neworiginal:
For the life of me I cannot find an expanded view of the 1980 340 crankshaft. Is my index finger pointing to the thrush washer? Are there only 2 or are all 4 thrush washers (2nd pic)? I am putting the C shim between it and the PTO crank bearing. Being safe and I'm second guessing. Thanks
Interceptor398:
Not sure if this helps?
neworiginal:
Yes, thank you.
mswyka:
I just checked one of our cranks and see that the shim is between the mag side center bearing and the thrust washer. I will try to post a photo.
mswyka:
Here is a photo of the shim location.
Navigation
[0] Message Index
[#] Next page
Go to full version
