General Category => General Discussion => Topic started by: rogers26 on November 21, 2017, 07:07:50 PM
Thanks for the add! I have a intruder and was wondering if the drifter 440 is the same motor
Welcome to the site!!! They have some things in common but for the most part are not the same.
Really want to build a couple fan motors for oval racing and need to know if the crank , jugs and heads are the same? intruder, drifter, or other models
Intruder jugs are set up for twin carbs and the jugs can be on either side. Drifter jugs are set up for 1 carb and the cylinders are only left or right. I've never tried it but the bottom ends may work for both.
398. Thanks I am new with kawasaki but ready two learn
Intruder jugs will fit just fine on a Drifter bottom end.
Any of the T7 engines can swap jugs.
