General Category => General Discussion => Topic started by: mswyka on December 22, 2021, 06:54:07 AM
Good morning. I am checking to see if anyone knows a source for new Intruder/Invader external ignition coils?
The coil on our pink sled was dead and I have gone searching through my usual sources and am either coming up with no listing or no stock.
Are others seeing this same thing?
Hi Mark, I have lots of cars Mark if you need one
Like many things during this pandemic they seem to be non existent.
There are some options
I know of a few that have successfully used a Polaris Indy CDI/Coil unit on these engines.
I have a Polaris cdi that I will be installing on my Invader. A reputable engine builder recommended it for a better timing curve. It requires moving the stock stator plate significantly.
It will be interesting to hear how that works out.
A Polaris CDI unit gives a similar timing curve to a 82-84 Liquifire or a 4/6.
He built a standard Invader motor with Polaris CDI, custom heads, porting, and 4/6 pipes that ran mid 80s HP on the dyno with a nice broad power curve.
Yeah, should be similar to the Liquifire, but the 4/6 uses an older cdi similar to the old arctic cat. Many swap them out for Invader heads and ignition for an improvement.
I now have an external ignition coil on "backorder." I am told that delivery will be in March. We will see how that works out.
I'm sure I have a good used coil if you need one.
Coils finally arrived!
That took a while!
I think some of the 2 stroke Kawasaki motorcycles used these coils to
That took a while!
Better late than never.
