General Category => General Discussion => Topic started by: kawhead on December 21, 2017, 02:56:15 PM
where do you all buy the correct fuel line,7/32, the good stuff. I'm not set up as a sled shop anymore and lost my access to the basics. also, what do you use to replace the 1078 belt.
www.mfgsupply.com
https://www.mfgsupply.com/media/catalog/product/cache/1/image/1000x/c1eafbadb87a261db73e07c2de8fe883/h/p/hp3012_2.jpg
This is where I got my last new belt. Seems at least as good as the 1078 was....and the price isn't bad.... 8)
I would also like to hear if anyone has found some decent 7/32 fuel tubing....everything I have found is the plain, old vinyl that starts to get hard within 1 year.... :(
In the past I used Tygon tubing. I've never had a problem with it but it is expensive.
This is not 7/32. However a few years ago we had a problem with fuel leakage. We switched to this smaller line. It takes a little stretching to get it over the fittings, but we have not had any problem with fuel leakage since we started using it. Unfortunately I don't remember where I bought it.
I have been using regular black automotive fuel line. lasts for years.
Parts unlimited their fuel lines seem to be good used this stuff for years the
blue polyurethane fuel line [0706-0106] PARTS UNLIMITED They have other sizes too.
http://www.parts-unlimited.com/products/?productId=432898&partNumber=07060106
you get by with 1/4 on hi perf sleds?
I have some of that 7/32 fuel line if you need it. It's new, the color is yellow. PM me if you need some. Doug
I would like to replace the oil injector lines. Where can I purchase that? Thanks!
I was doing a little fishing for some other things and tripped over this cross reference for the 1078
http://www.daycoproducts.com/parts?category_id=1139&year=1980&make=46&model=5197&description=12414
According to Dayco they are referencing the HP 3012 at 46.69" long and 1.25" wide
i just used a hp3012, worked good
