General Category => General Discussion => Topic started by: mrcsnow on December 14, 2014, 12:42:09 PM
1982 Kawasaki Intruder parts needed
looking for NOS or nice used
-airbox
-carburetors 2-34mm
-throttle cables
-windshield
-seat
-cdi box with plug wires
mrcsnow@yahoo.com
(815)762-6868
Thanks -Matt
Matt, we have one low black windscreen left.
On those carbs, did 82 use 34mm? I had thought that all of the Intruders used 32mm powerjet carbs.
Yes my bad they have 32mm pjs. Do you know how many 1982 Kawasaki Intruders were made?
I found a windshield
SPI throttle cables are no longer available.
I'm also looking for a cdi box with plug wires
thanks -Matt
Someone here on the site should have the statistics with the number of sleds produced each model year. Have you tried Dennis Kirk for the throttle cable? While it may not be perfectly identical, the Invader cable should be able to be made to work.
all intruders use similar carbs, just jetting changes.
1982 Models
Intruder
Color Crimson Red
Model no: ST440-A4 Engine: TA440C
Frame serial number sst440a4 -012600---014601
Engine serial number TA440C-012603----015629
2001 total produced
I was able to find everything except a coil pack with plug wires for a 1982 Intruder.
Does anyone have one or know someone who does have a coil pack with wires?
Thanks -Matt
I have a good used coil and wires off from an Invader, but I'm not sure if it'll fit? I'm sure the coil is the same, but the wires might be different?
82 intruder used the box/coil 1 piece unit....
