Tech Information => General Help => Topic started by: moz_21 on February 16, 2018, 10:59:57 AM
Has anyone experimented with a shorter drive belt? I'm using the stock 1078 belt but am out of jackshaft adjustment. I wanted to try running a little tighter belt to fix some bogging. Clutches are aligned with the tool.
Did you try another belt? If you adjusted the center to center distance with the tool and the belt is too loose I would think there is a problem with the belt...
New belts yields very minimal improvement. I also have minor grooving on my primary clutch that I just noticed, toward the bottom. However, belt deflection is a little high, 1 3/4.
Maybe the bogging isn't caused by the clutches/belt?
Might not be. To be fair, I grew up on this thing and it's never ran better than I've got out now. Crank seals are amazing.
Running a shorter belt would lower clutch engagement and upshift, I don't think that would help with a bogging issue.
