General Category => CLASSIFIEDS: buy, sell or trade here => Topic started by: maxspeed6 on February 07, 2015, 06:08:34 PM
Hi, im new to the forum and i have a 1981 invader 440.
I search for primary clutch ramps ( or the bushing only ) Mine is really worn and i want to buy some news to rebuilt my clutch.
Oem part number = 39152-3007
Replacement Kawasaki Primary clutch ramp bushings. www.mcmaster.com part number: 6679K15
Agree!
Perfect replacement and inexpensive!
I just rebuilt my invader clutch using these.
They also have the plastic washers if needed.
Great information! Has anyone found a replacement for the pin that the ramps are mounted on pn#92043-3001? 5kaws do you have the # of the plastic washers? Joel
5kaws, Great info! Please post the plastic washer info in the parts interchange thread.
Joel, I have lots of good used ramp pins if you need some pm me.
The pins are available at the dealer. ATV and Mule clutches are similar.
Yes Id be happy give the part number for them. Give me day of two, tossed the bag out with the part numbers on there.
Also found invader/intruder rear suspension bushings from there also. I'll get the bushing part number too
McMaster is 15mins from my house and my friend works there. He got me the orings for the carbs. I have 250 orings lol it's way to much but for 1.25 for the 250 heck lol.
Also we found a perfect match for the carb float bowl screws. -mike
Renumbered Kawasaki Parts that are still available from a dealer:
Pin 6.5x10x38 old pn# 920243-3001, new pn# 92043-1370
Bushing 40x44x12 old pn# 92028-3008, new pn# 92028-1511
Spacer 10x16x.8 old pn# 92026-3001, new pn# 92026-1304
Nut, special lock 6mm pn# 92019-008, still available under same part number
Roller old pn# 92122-3001, new pn# 92122-1152
Washer, spider old pn# 92022-3016, new pn# 92022-1899
Bolt, flanged 6x20 old pn# 92001-3001, new pn# 92150-1014
Bushing 32x36x20 old pn# 92028-3005, new pn# 92028-1513
Bushing 25x28x30 old pn# 92028-3004, new pn# 92028-1514
Bushing 50x55x20 old pn# 92028-3006, new pn# 92028-1512
Washer Split old pn# 92022-3001, new pn# 92022-1897
Washer, special conical old pn# 92022-3015, new pn# 92022-1901
Guide, Wear (plastic clutch guides 79-82) old pn# 13070-3002 new pn# 13070-1185
The roller also have a bushing , do you know if he come with the roller ?
I had hard time finding some of those parts from that list from kaw.
Most of them numbers changed again and I couldn't find them.
Unless I looked in wrong place.
same bushing in the rollers and weights
i just called my kawi distributor and the pin, roller and plastic washer are still available.
Roller is around 15$
Pin is around 6$
plastic washer 3$ :o
Note that the price is in CA $
I wanted to change all those parts but at this price, i will buy just the pin and i will change all the bushing from MCMASTER and washer too.
Ok so I found the number for the plastic washers
Washer # 95649a241
There's a lot of stuff at that place that work for the kaws.
Thank you for your help ... i already knew this place we buy there often at my job. It's simply amazing how many stuff they have in stock
that place has an amazing selection.....
I had to pass thrue my job company to buy from McMaster, he don't sell to private person for international purchase ... >:(
Yep
I go threw my buddy , he works there and gets its at his cost for me.
Thanks alot for the parts number. I rebuilt my clutch last weekend and my sled finally run great
No problem.
Do you if someone had some spare "F" ramps ?? One's of mines was broken yesterday. However, i was very careful when changing my bushings ......
Check ebay ,or another member on here.
