Author Topic: Jetting for fall grass drags 440 Invader  (Read 42883 times)
Re: Jetting for fall grass drags 440 Invader
« Reply #30 on: December 08, 2014, 05:07:13 AM »
JDMatt...    sent you a pm.     Tory
« Reply #31 on: December 08, 2014, 08:35:11 AM »
c weights were first design...f weights will work better....if you stick with a yellow spring[std],you may want to lighten the bolt/washers....
JDmatt
« Reply #32 on: December 08, 2014, 07:18:26 PM »
Enlighten me - when you say lighten the bolts/washers, are we talking grinding weight off, or going to a different bolt completely?  Is there documentation available on tuning the Kawa clutches?
Matt
« Reply #33 on: December 08, 2014, 08:36:13 PM »
Lightening the weights can mean removing some of or all of the washers, using shorter bolts, or even using aluminum bolts.
« Reply #34 on: December 09, 2014, 08:15:01 AM »
gixxer6 is correct....with a yellow spring i'd start with a lighter bolt...
