Author Topic: Stock carb jets for invader 440  (Read 26684 times)
Re: Stock carb jets for invader 440
« Reply #15 on: November 25, 2014, 08:25:23 AM »
when you get the mag seal out it will be apparent why it won't run right.
tool13x
« Reply #16 on: December 04, 2014, 09:57:38 PM »
Just thought I would throw out an update:
Carburetors have been fully rebuilt, all new gaskets, o-rings and jets. I found out that a small round style main jet works as a replacement for the econo-jet. I ordered a Mikuni  part no.  # N102.221-120 and its exactly the same as the jet I pulled from the carb.
 I am in the process of replacing the crank seals as you guys recommended. I split the case and removed the old ones tonight and what did I find?
The mag seal was in terrible shape, just as kawhead predicted. Im glad I took everyones advice and replaced these seals now.
Hopefully this weekend I will be able to tell you guys the sled is back together and runs like new.
« Last Edit: December 04, 2014, 10:00:35 PM by tool13x »
5kaws
« Reply #17 on: December 05, 2014, 07:07:50 AM »
You got lucky , sometimes those springs get sucked up into the crank or top end .  I've seen it go both ways unfortunately.
« Reply #18 on: December 05, 2014, 09:26:37 AM »
a lot of your problems will now go away....it'll start warm with a small tug and idle nice....way to stick with it,half of fixing stuff.
