Author Topic: Finally got the restore project running. bogging issue  (Read 33957 times)
heiner921
Re: Finally got the restore project running. bogging issue
« Reply #30 on: December 10, 2014, 09:12:57 AM »
Enriches are hooked up.. tank was cleaned. Fresh gas. Will check for kinks..I did add an inline filter before the fuel pump
« Reply #31 on: December 10, 2014, 12:24:34 PM »
get it to bog,lightly choke each cyl at carb,pull boot up and feel the slack in cable, as you choke one side it tells witch cyl or both and rich or lean...
