Vintage Kawasaki snowmobile community - keeping the legend alive!
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Welcome to KawasakiTrax.com Online Community
Tech Information
General Help
79 Invader
« previous
next »
Print
Pages: [
1
Author
Topic: 79 Invader (Read 15233 times)
Fry199
Newbie
79 Invader
on:
January 18, 2015, 02:35:33 PM »
Does anyone live in ohio or near ohio? Im having a hard time get my invader tuned in I put carb kit in did crank seals it deffinetly helped but not 100% yet some times it starts up and runs great others its real boggy and wont idle I ohmed the stator its right on specs. any help would be appreciated. If you live near ohio maybe we could get together on a weekend and tune this in?
Logged
Hero Member
Re: 79 Invader
Reply #1 on:
January 18, 2015, 04:02:47 PM »
I don't live in Ohio, but have a couple of questions. First, how clean are the carbs and the jets? The second question is whether or not the primer may be leaking?
Logged
Intruders: 1978, 1979, 1981 Custom (Pink)
Invaders: 1980 440
Projects: 1981 Invader 440
Fry199
Newbie
Re: 79 Invader
Reply #2 on:
January 18, 2015, 04:22:24 PM »
Crabs are spotless cleaned them at least 15 times trying to figure this out I have new jets on the way pilots are chewed up from being taken in and out so many times the tank is spotless fuel pump is clean the filter in the tank Is clean I even added filters on the fuel lines from the pump to the carb. I cant get it to run half way decent both cylinders get hot when I pull one plug wire off in kinda spits and sputters I pull the other off it dies out. I know the primer t has a leak when I prime it the t squirts fuel.
Logged
5kaws
Full Member
Re: 79 Invader
Reply #3 on:
January 18, 2015, 05:13:33 PM »
I live in Ohio. 20 min south of cleveland.
-mike
Logged
Fry199
Newbie
Re: 79 Invader
Reply #4 on:
January 18, 2015, 05:21:59 PM »
5kaws could you please email me josh_199@hotmail.com I'm at a lost cause with this thing
Logged
5kaws
Full Member
Re: 79 Invader
Reply #5 on:
January 18, 2015, 07:21:44 PM »
I sent you an email
-mike
Logged
Administrator
Hero Member
Re: 79 Invader
Reply #6 on:
January 19, 2015, 07:26:16 AM »
Check the gas line in the tank.
Logged
Hero Member
Re: 79 Invader
Reply #7 on:
January 19, 2015, 08:25:02 AM »
unhook that primer first off....the cyl that doesn't stall the motor is at fault, pto or mag?
Logged
Fry199
Newbie
Re: 79 Invader
Reply #8 on:
January 19, 2015, 11:49:28 AM »
Pto
Logged
Fry199
Newbie
Re: 79 Invader
Reply #9 on:
January 19, 2015, 01:39:52 PM »
Now it seems to be okay when I pull a plug wire off it dies out just as much as the other my temps on the cylinders are about the same plugs look good it idled fine I am running some premix in there with the oil imjection hooked up as well because I just did crank seals and didn't want it running on dry gas while I bled the oil system
Logged
Hero Member
Re: 79 Invader
Reply #10 on:
January 20, 2015, 10:18:31 AM »
sounds like it needs to be run a little to clear out.
Logged
Print
Pages: [
1
« previous
next »
Tech Information
General Help
79 Invader
