Author Topic: Help invader won't idle  (Read 12316 times)
Fry199
« on: January 25, 2015, 10:20:28 PM »
I got a 440 can't get it to stay idle did the seal carbs are clean out new high flow filters on it runs good in the mid rpm and higher Rpm just won't sit at an idle any help would be great
Re: Help invader won't idle
« Reply #1 on: January 26, 2015, 06:17:54 AM »
There are a couple of things that I would suggest that you check.  Did you replace the pilot jets?  If not that would be my first move.  Second run a small wire through all of the openings for the pilot circuit including the air bleed channel and double check the setting on the air bleed screw.  Pull the needle jet and check to be sure that the moat around the top of the needle jet is clean and that the pilot air passage is clear (note the small hole in the attached photo).  Our experience has been that most of our idling problems relate directly to the pilot jet and cleaning out the moat at the top of the needle jet.
« Reply #2 on: January 26, 2015, 01:33:30 PM »
Except for the 4/6....     LOL!!!!    (Inside joke)           Tory :P
« Reply #3 on: January 26, 2015, 02:01:04 PM »
Tory, you are very correct.
Fry199
« Reply #4 on: January 26, 2015, 03:17:59 PM »
Anyone in Ohio or surrounding states that could help me tune it in I'm at a loss cause with about to give in and sell it and buy something efi
« Reply #5 on: January 26, 2015, 03:32:51 PM »
  Had the 4/6 out in the field today...   all was well as long as I stayed on the choke while riding!  Haha!  Once I got through the intial BOOOOOOOGGGGGG....  she hauled the mail!   LOL   It's on my bucket list  "more projects> 8)
