Author Topic: Clutch help!  (Read 24533 times)
Re: Clutch help!
« Reply #15 on: February 05, 2015, 08:20:40 AM »
if the jackshaft is worn[tapered]were the clutch opens it lets the coupler flex, not good for the coupler, i take a new bushing and slide it down the shaft to check
Re: Clutch help!
« Reply #16 on: February 05, 2015, 08:21:58 AM »
i bet tory has a pipe of drivens,[ i do] not much call for replacements
Curtisrmx250
Re: Clutch help!
« Reply #17 on: February 07, 2015, 09:08:03 AM »
the kawi clutch isnt bad it just didnt have one. Its all a custom build the only thing I got that's kawi is the tunnel belly pan and hood. I'm putting a suzuki motorcycle engine in it, Skidoo mxz ifs, and polaris m10 slide rail. But I'm still running a snowmobile clutch. I have skidoo drive but I think the skidoo tunnel is narrower then the kawi.
Curtisrmx250
Re: Clutch help!
« Reply #18 on: February 07, 2015, 10:19:32 AM »
I love kawi's I have since I was 14 my pops bought me an invader ltd. always loved the looks of them. I'm 27 now but still have the ltd mono head. Plus a 4/6 a 340 invader a 440 intruder and the project intruder.
Habbeli
Re: Clutch help!
« Reply #19 on: March 12, 2015, 08:42:21 AM »
Lol...   bad luck!  Just replace your bushings and wear shoes and you'll be fine.  The biggest benefit to changing your secondary would be for a helix profile change (multi angle helix) for a better shift out...  or converting to 1 3/8 from 1 1/4" belt width for increased efficiency and/or top speed.  Stock helix is 35 deg.  The steeper the angle 44 vs. 34 deg the harder the shift out and the 34 on top keeps the Rpms where they need to be.
Tory944; Where kan i find a 44/34 helix?
Habbeli
Re: Clutch help!
« Reply #20 on: October 27, 2015, 07:36:15 PM »
Tory 994, where do you find such a helix or have you done it yourself?
