Author Topic: no lights anywhere  (Read 8573 times)
Pmlecom1
  • The Blue Demon
no lights anywhere
« on: March 03, 2015, 02:19:31 PM »
What would cause the sled to not have any lights , key functiuon or kill switch function.  Obviously I connected the main harness.  Could it be the voltage regulator or something?  Sled runs great, during the day.  I am working the bugs out one issue at a time.
Gilson435
Re: no lights anywhere
« Reply #1 on: March 03, 2015, 02:29:37 PM »
Are the bulbs blown? A bad Voltage regulator could cause that. Check with a volt meter to see how many volts it's putting out. Could have a bad lighting coil too. Check your wiring and connections. It could be a bad ignition switch as well if it's not making contact in the lights on position.
« Last Edit: March 03, 2015, 02:35:08 PM by Gilson435 »
69 Panther 372 JLO
73 Gilson 435
80 Kawasaki Intruder 440
2002 Polaris XCSP 800
« Reply #2 on: March 03, 2015, 06:10:49 PM »
Check to make sure that the wiring harness connector at the engine is connected properly and all the wires are seated fully and making contact.
« Reply #3 on: March 03, 2015, 08:38:04 PM »
Guess you will need two sleds now.  One for day and one for night!! ;D Mad Kawi strikes again!!  Sorry, could not resist that one.  LOL 8)
