Author Topic: 1980 intruder bent steering arm?  (Read 9189 times)
wisc79intruderguy
« on: September 20, 2015, 07:12:02 PM »
Hello again I was taking my skies and spindles out to clean and lube them they needed it! My question is the steering arm supposed to be bent right in the middle. The front of the belly pan was cracked at one time but I repaired it last fall. Thanks for any help
Re: 1980 intruder bent steering arm?
« Reply #1 on: September 20, 2015, 09:35:23 PM »
A picture of what you are looking at would be helpful.  If it is what I think it is the answer is yes if the handle bar is attached to it.
« Last Edit: September 21, 2015, 07:48:31 PM by Interceptor398 »
« Reply #2 on: September 21, 2015, 06:14:21 AM »
The steering shaft has a wahoo in the middle, but the two steering arms should both be straight.
« Reply #3 on: September 21, 2015, 06:45:15 AM »
Like mswyka said, the steering shaft from the handle bars to the frame should have a bend in it.  The other shafts should be straight.
wisc79intruderguy
« Reply #4 on: September 21, 2015, 01:08:44 PM »
Thanks i'll try to straighten it.
