Author Topic: 4/6 1 piece head swap  (Read 12537 times)
78invader2
« on: October 05, 2015, 08:30:16 PM »
My 4/6 motor has the individual heads on it, and I came across a 1 piece head for both heads. Can this swap over and are there any benefits to the one piece head over the two piece?
Re: 4/6 1 piece head swap
« Reply #1 on: October 06, 2015, 12:13:14 AM »
The 1 piece head (mono-head) has better coolant flow than the single cylinder heads. I would think they are probably not interchangeable as the cylinders may not have the cooling ports line up, but that is a guess. I also doubt the gaskets would line up either.
« Reply #2 on: October 06, 2015, 06:41:34 AM »
No.  They are complete different designs and are not compatible.  The two piece heads have 8 holes for head studs, and the mono-head only has 6 (per cylinder).
« Reply #3 on: October 06, 2015, 06:59:26 AM »
What he said.
78invader2
« Reply #4 on: October 06, 2015, 02:07:30 PM »
Okay, so since mine has individual heads is it still have the 4 to 6 ports or is it just considered a LTD motor? Im guessing mine is the earlier version of the motor?
« Reply #5 on: October 06, 2015, 02:55:19 PM »
The 4/6 motor is based on the standard Invader motor.  It has extra transfer ports in the cylinders and 2 spark plugs in each individual head.  The 81-82 LTD motor is completely different design that is shared with the Interceptors.
From my experience, the 4/6 setup is the most sought after of all the older Invader design motors.  And the Interceptor setup is the most sought after of the newer mono-head design.
78invader2
« Reply #6 on: October 06, 2015, 07:52:52 PM »
Okay thanks!! Im still in the market for the gears you have I just gotta find time to see what I have.
