Author Topic: Mono head LTD piston differences  (Read 7626 times)
Teherr
« on: November 09, 2015, 08:43:48 PM »
I am assembling an LTD engine with new cylinders and pistons that came with it.  1 cylinder and 1 piston were marked PTO.  The second piston (non pto side) has a slightly different rear skirt (tapered).  the old pistons appear to be the same pto and mag side.  Has anyone seen this?
This slight difference does change intake port opening some (corners open sooner).
On another note,  I had to file the corners of the PTO side skirt or it did not clear (hit) the crank when bottom dead center.  Is this normal?
440 Invaders
440 LTD Monohead
Liquifire
80' 4/6
Intruder Ice Oval Racer
74 El Tigre T7 Free Air
80 Polaris 440 TX
250 & 340 Enticers
Re: Mono head LTD piston differences
« Reply #1 on: November 10, 2015, 06:32:24 AM »
Both pistons and cylinders should be exactly the same.  You shouldn't need to file the piston skirt to make it fit.
