Author Topic: Switching Head Nuts  (Read 9834 times)
Truder78
Switching Head Nuts
« on: November 18, 2015, 08:14:51 AM »
Has anyone ever used regular nuts on the invader heads to rule out the bottom out problem? I know you can add a washer to the acorn nut but what thread size and grade nut would you recommend if you wanted to switch them.
Thx
Kawasaki Snowmobiles
Re: Switching Head Nuts
« Reply #1 on: November 18, 2015, 08:41:24 AM »
 It looks like the studs and nuts are metric 8 mm.
 I have never personally tried it, but I would think it would work fine.
 Use a flat, and a lock washer....or possibly you could also use a nylon insert nut, instead of a regular nut.
 With these nuts torqued to only 16 foot pounds, I wouldn't think you need to go to a grade 8 fastener.
 Perhaps someone on here can add more info.
« Reply #2 on: November 18, 2015, 10:14:59 AM »
I have added a flat under the stock washers.  In one instance I've needed to use 2 extra flats.  I like the look of the stock acorns, so I haven't swapped them out.
FYI the added washers didn't solve my leaky head gasket issues...
Truder78
« Reply #3 on: November 18, 2015, 12:27:21 PM »
Leaks seem to be hit or miss for me I will do the wd40 wet sand as listed here on the site is that for the cylinder tops also? or just the heads
« Last Edit: November 18, 2015, 12:29:54 PM by Truder78 »
« Reply #4 on: November 18, 2015, 01:33:11 PM »
The only thing that I could get to permanently seal the heads was NOS 4/6 gaskets.  I tried NOS Kawi gaskets, NOS Deere gaskets, Cometic, Winderosa, Kimpex, and Marshall.  I tried with sealant (several types), without sealant and different combinations of sealant and gasket brand.  I tried sanding the head and cylinder per the manual.  I finally found the NOS 4/6 gaskets and never looked back.  BONUS they are re-usable!
« Reply #5 on: November 18, 2015, 06:18:44 PM »
 I have used standard 8mm nuts. No problems
