Author Topic: Spacer between intake manifold and jugs?  (Read 18248 times)
Viking
« on: January 06, 2016, 06:44:01 PM »
I'm disassembling and cleaning motor parts on drifter. What's with the spacer? what's it called and where to get new ones? its plastic 3/8 inch thick same shape as gasket. does it come off? I chip the corner with hammer trying to get it off
« Last Edit: January 06, 2016, 08:11:40 PM by Viking »
Re: Spacer between intake manifold and jugs?
« Reply #1 on: January 07, 2016, 06:06:42 AM »
They are called isolator blocks
Viking
« Reply #2 on: January 07, 2016, 07:39:34 AM »
Thank you. If they break up while removing. can I get them? do I need them?
« Reply #3 on: January 07, 2016, 07:48:43 AM »
The SA340-A4 pn is 16073-3002.  The SA440-A4 pn is 16061-517 if you go looking for NOS ones.   I would think there are plenty of used ones out there.  You might get by without it but I would keep them in there.  Kawasaki put them in there for a reason.  Good Luck
