Author Topic: Kawasaki sno jet SST wiring diagram?  (Read 11199 times)
« on: January 15, 2016, 09:56:46 AM »
My buddy is having troubles with his SST.   Anyone have a manual with a wiring diagram that they could share?  It has the Yamaha 440 motor.
Re: Kawasaki sno jet SST wiring diagram?
« Reply #1 on: January 15, 2016, 01:59:39 PM »
 This picture is barely legible, but it may help. I added the hand written numbers because the originals are so tiny.....just realize I can't be certain which is a "6" or an "8". It almost impossible to tell the difference.
 It's hard to read, but if you move clockwise from the engine....you have the tach, tailight, brake lever, headlight, speedometer, key switch, throttle, voltage regulator.
 This is from a 1975 manual.
 You could also search:   www.vintagesnow.com/Sno-jet.html      and see a better picture, or different model years, of the wiring diagram.
Rick
« Last Edit: January 15, 2016, 03:53:20 PM by rminier »
Invader440
    • Curt's Snowmobiling Page
« Reply #2 on: February 13, 2016, 05:43:36 AM »
Here you go if you still need it.  This is the 77 wiring diagram. http://kawisncats.freevar.com/sst.jpg
