Author Topic: P85 clutch  (Read 9150 times)
Sledhead60
P85 clutch
« on: January 30, 2018, 10:32:56 AM »
Just wondering what I would need to have as far as spring color and weights for a Polaris p-85 clutch for it to run right on my 79 440 invader. Also, can I use the same drive belt and clutch bolt?
F500-92
Re: P85 clutch
« Reply #1 on: January 30, 2018, 11:17:23 AM »
I'm working on my P85 clutching at the moment as well
 Springs are difficult to say.  Every manufacturer measures spring rates differently.  I have about a dozen springs but no idea who made them.   Polaris purple is not the same as Aaen purple vs EPI purple.
 I did put them all on a spring rate rig and settled with a spring at a rate of 70lbs at 2.5" compressed height and 220lbs at 1.5" with Polaris 10-56 weights.  This combo ended up with perfomance very similar to the stock Kawi clutching.
I used the original belt and used the Kawi Clutch bolt with the Polaris clutch retainer washer.
« Last Edit: January 30, 2018, 11:25:21 AM by Sully »
Re: P85 clutch
« Reply #2 on: January 31, 2018, 08:54:46 AM »
how much material must be removed from the Polaris clutch to clear the vader bulkhead?
Re: P85 clutch
« Reply #3 on: February 01, 2018, 05:27:09 AM »
Aaen clutching book
Re: P85 clutch
« Reply #4 on: February 02, 2018, 04:48:50 PM »
It depends a bit on which p-85 clutch you use.  There are a couple different offsets. The ones that take the ring gear for the electric start need more taken off.
