Author Topic: LTD carb question  (Read 10581 times)
sgtobias
LTD carb question
« on: February 05, 2018, 08:56:21 AM »
1982 440 LTD
Has Keihin carburetors . I have cleaned them (except for "air jet") and checked for correct jet sizes.
I have a bog in the middle. It idles fine and goes at slow speed fine, but when I accelerate, it bogs and then finally goes.
I have adjusted the air screw with no luck (although I'm guessing that is more for low rpm)
I have also played with the screws on the "accelerator pump"
Can't figure out if I'm too rich or too lean.
Need help
Re: LTD carb question
« Reply #1 on: February 05, 2018, 01:10:42 PM »
Have you confirmed that the accelerator pump diaphragms are good and that the two check valves on each pump are moving and seating properly?
« Reply #2 on: February 05, 2018, 04:46:59 PM »
tap the choke when it bogs to see if its rich or lean
sgtobias
« Reply #3 on: February 05, 2018, 09:05:32 PM »
Thanks for the ideas. I will check them out later this week.
Am heading for Grand Marais, MN tomorrow to do some snowmobiling.
« Reply #4 on: February 06, 2018, 06:26:20 AM »
We should all be so fortunate!  Those of us in NY with no snow are quite envious.
