Author Topic: Hey guys a couple of guestions  (Read 6316 times)
chaddyg8
« on: June 02, 2018, 11:19:45 AM »
It’s  a 80 440 drifter. Just picked it up. Put some fuel in it came back later and Crank case was full of fuel. Removed the pulse  line from the fuel pump and noticed fuel coming out. Remove spark plugs pulled forever got the fuel out. My question is are there rebuild kits for that small Mikuni pump or should I purchase a new one? Also how do you get to the bolts to remove that fuel pump? Remove the track? God I hope not. Lol thanks
Vader440
Re: Hey guys a couple of guestions
« Reply #1 on: June 03, 2018, 06:56:00 PM »
Yes you can find rebuild kits for them. I got mine from MFG Supply and they carry complete pumps as well. I would recommend replacing the whole pump. I've also read on here some people install a fuel shut off valve. The bolts should be locked in place, you should just have to take off the nuts.
chaddyg8
« Reply #2 on: June 03, 2018, 09:09:42 PM »
Thanks for the reply.  I wish they where Locked! The bolt and nut are turning on mine. I just cut the bolts off. Prob gunna mount the new fuel pump with self tappers or something.
