Author Topic: Wanted: 1980 Kawasaki Invader 440 speedo part  (Read 18346 times)
11c
« on: January 18, 2019, 08:19:19 PM »
I'm looking for the speedometer drive gear that inserts into the chaincase (on the outside of the case) that drives the cable and the gear inside the 90 deg piece attached to the cable.
I'd post a pic but this site won't let me post a jpg off my phone for some unknown reason.
« Last Edit: January 18, 2019, 08:27:43 PM by 11c »
Retired team SKI-DOO drag racer.
SEA-DOO rider now on warm sunny days.
Current vintage sled;1980 KAWASAKI INVADER 440
1971 & 1972 Firebird Formula 455's
Re: Wanted: 1980 Kawasaki Invader 440 speedo part
« Reply #1 on: January 18, 2019, 08:51:47 PM »
File size is likely to big.  Reduce it to about 1mb and it should work.
11c
« Reply #2 on: January 19, 2019, 04:20:45 PM »
O.k on my computer and not the phone I can post the pix.
So....am I right and there should be a small gear on a shaft inserted into the chain-case then the cable, I don't see how else it would work.
I need the gear if anyone has one.
« Last Edit: January 19, 2019, 04:23:49 PM by 11c »
11c
« Reply #4 on: January 20, 2019, 06:10:10 PM »
Thanks....
That looks like it's also missing a shaft that goes through the small hole inside the big nut end and possibly the gear inside that I think I'm missing. I think here should be two gears inside that adapter, one that the chaincase drives, then the lower one that transfers rotation to the cable itself.
I'll message the guy and see if he has any sort of drive shaft for the adapter.
11c
« Reply #5 on: January 20, 2019, 06:42:51 PM »
Can someone with one of these machines that has the speedo running off of the chaincase please unbolt that adapter from the chaincase and tell me if there's a small shaft or key running through there into the adapter.
I have the adapter, I have the cable, there's something missing.
A photo would help so I know what I'm actually looking for.
Pic below shows the adapter opened up with one gear, there should be another on a shaft to drive it??
« Last Edit: January 20, 2019, 06:46:50 PM by 11c »
11c
« Reply #6 on: January 20, 2019, 06:48:45 PM »
A few more pix of the empty adapter
« Last Edit: January 20, 2019, 06:51:41 PM by 11c »
Vader440
« Reply #7 on: January 20, 2019, 08:21:49 PM »
This is all I'm seeing in the parts manual. Really doesn't show a breakdown of that part.
11c
« Reply #8 on: January 20, 2019, 08:34:51 PM »
Thanks Vader440
At least now I can see that there is a separate key/drive shaft that I'm also missing and it's not a one piece gear and key.
So...WANTED, one drive key, one complete adapter with BOTH gears inside.
« Reply #9 on: January 21, 2019, 07:44:41 AM »
I don't believe they are meant to be taken apart.
I may have an extra one, I will look tonight.
11c
« Reply #10 on: January 21, 2019, 06:47:00 PM »
I agree,  there was a tiny pin holding the large nut on to the adaptor body. For whatever reason it's gone and the key and the gear it drives must have exited  out the exhaust hole in the pan.
If you have one I would buy it, the eBay guy didn't answer my questions.
I could always just mount my GPS for speed but I like everything working as it should ...drives me crazy if something isn't working.. lol
« Reply #11 on: January 21, 2019, 08:27:43 PM »
What are the numbers stamped in the round end plate?
11c
« Reply #12 on: January 21, 2019, 09:35:32 PM »
I looked with a strong magnifying glass and there are no numbers or even a trace of a number. Only a "L" on the large nut.
Strange it has no part number anywhere unless it was on a small decal that fell off 30 years ago...
Mine has slight differences than the one in the ebay ad posted above.
« Last Edit: January 21, 2019, 09:39:39 PM by 11c »
« Reply #13 on: January 22, 2019, 09:04:00 AM »
For the SS440-A2 the part number for the adaptor is 41077-3501  "Adaptor, speedometer drive". The book does not say what ratio this adaptor is. I have a couple that are 1-3 and 1-1.375 etc.  I will go out later today and check my 80 Invader to see if it has the ratio stamped in the adaptor.
« Reply #14 on: January 22, 2019, 05:11:13 PM »
Checked my 81 Invader and the adaptor is stamped 1-3.
