Author Topic: Just picked up a 440 Invader  (Read 21251 times)
Metalman
« on: December 29, 2012, 03:40:22 PM »
Just picked up a 440 Invader. I managed to get the Invader, a new 78 Intruder hood still wrapped in the original plastic, some skis and wear bars for $450.00.
 The Invader is in pretty good shape, runs well and just needs the primer fixed and some new slides.
« Last Edit: December 29, 2012, 04:34:03 PM by Metalman »
Re: Just picked up a 440 Invader
« Reply #1 on: December 29, 2012, 04:14:06 PM »
nice find
 The 78"s were the best looking Intruders. That hood should be worth some bucks
Metalman
« Reply #2 on: December 30, 2012, 03:04:31 PM »
The Invader runs really nice! Put all new fuel lines on today and fixed the primer as it looked like an Exxon spill under there when I put gas in it. Starts on one pull, no bog or idling issues. Needs a few minor maintenance issues fixed
 Think I will tear it down next weekend and put some seals in it and maybe get rid of this grouser bar track and put one of the rubber ones on it. Should probably put the 81 suspension I have on it while I'm at it.  :)
« Reply #3 on: December 31, 2012, 12:07:36 PM »
When you change to the rubber track, you do have to change to the 4 wheels across the rear idler shaft. They are a touch bigger. otherwise you will never get the track adjusted right. Been there!!
Also, balancing the carbs makes a big difference too.
The 81 suspension on the Invaders is about the same as the 78..
« Last Edit: December 31, 2012, 12:09:44 PM by jimvw57 »
« Reply #4 on: December 31, 2012, 01:20:45 PM »
The 81 Invader rear skid is completely different than the 78'.  The 81' has a Vari Ride, which has a much better ride than the 78-80's.
« Reply #5 on: December 31, 2012, 02:56:26 PM »
Not necessarily, my 82 has a "Vari-ride" sticker on it but has the same suspension as the earlier Invader.  There is not an easy way to put a Vari-ride suspension in place of a standard Invader suspension. Spring adjustment 'hooks' would have to be added to the tunnel.
« Reply #6 on: January 01, 2013, 08:41:23 AM »
I bet that 82 was an Intruder....You are correct, 82 Intruders had standard skids with a Vari ride sticker.  But 81' Invaders have true Vari Rides in them.  At least every 81 Invader that I have ever seen.
« Reply #7 on: January 01, 2013, 08:57:46 AM »
The Vari-ride suspension doe ride much better, have it on my 4/6.
