Author Topic: Season has officially started  (Read 23611 times)
Re: Season has officially started
« Reply #15 on: December 08, 2019, 02:31:25 PM »
Gorgeous day here in New York.  So much so, that I thought it would be a good day to get another pair of sleds out of the machine shed. So we set to work on the TOC and one of the Intruders that we want to take up to the camp.  Neither one wanted to do much initially.  Finally just about when I was going to give up the TOC fired up.  What a sled, the ride home was exhilarating - snow flying, skis in the air - what snowmobiling should be and, at least around here, so seldom is.
Then it was time for the Intruder.  That turned out to be a different story.  Either the primary or the secondary was not working so it was going about 10 MPH at 5000 RPM.  And then, half way home in a place that has historically been called the "Rabbit Swamp" and I am sure by the name you can imagine why, she bogged and revved, bogged and revved and then finally just quit.  After the long walk of shame back to the highway so my wife could pick me up, I took the TOC out to pull the Intruder home.  And of course, I get it home and it drives into the garage like nothing is wrong.
But, a gorgeous day none the less.
« Reply #16 on: December 08, 2019, 03:02:24 PM »
Split end on the pick-up line for the primer
« Reply #17 on: December 08, 2019, 09:15:47 PM »
Primers and primer lines are a week spot.
« Reply #18 on: December 09, 2019, 07:18:30 PM »
Turns out that the secondary is frozen to the shaft.  I cannot get it to separate and I have yet to get it to come off the shaft.
I am open to suggestions on removing the secondary.  Of course it might be easier just to swap in a new jackshaft.
Thoughts?
« Reply #19 on: December 09, 2019, 10:05:43 PM »
Some kind of penetrating and a few days of waiting??
« Reply #20 on: December 11, 2019, 06:49:10 PM »
I should buy stock in PB Blaster.
Spraying morning and night for the last two days.  Put a puller on one side and gave it a good whack with a sledge hammer from the other side and she is now off the sled.  Now to find a suitable replacement.
« Reply #21 on: December 16, 2019, 06:30:07 PM »
Waiting for a new voltage regulator, and the next storm.
