Author Topic: 1979 vrs. 1879  (Read 8615 times)
1979 vrs. 1879
« on: December 24, 2019, 01:06:09 PM »
It is interesting to see the difference a hundred or so years will make.
Re: 1979 vrs. 1879
« Reply #1 on: December 25, 2019, 06:22:24 AM »
That is interesting we looked through the old albums the other day and saw when the 1st Case steam engine was built the mid 1800's just think for a second all those hot forge tables to make all those heavy gears probably days to make verses what we do now is take a block set it into a CNC mill less then 5minutes you have your part times for sure changed
Re: 1979 vrs. 1879
« Reply #2 on: December 25, 2019, 10:01:20 AM »
They both used horse power and produce exhaust when being used. ;D
Re: 1979 vrs. 1879
« Reply #3 on: December 26, 2019, 04:30:11 PM »
The cutter has been in my wife's family for at least 4 generations.  Her dad could remember his grandparents using the cutter for transportation in the winter.
The question will be whether or not four generations from now if  my family still has a running Kawasaki.
Re: 1979 vrs. 1879
« Reply #4 on: December 26, 2019, 05:21:17 PM »
We there even be gas to run them??
