Author Topic: 4/6 Cylinder identification  (Read 7832 times)
Vader19
« on: January 26, 2021, 07:47:58 AM »
Good morning, I was wondering if anyone could tell me what the 4/6 cylinders have for casting numbers?  I recently picked up a 4/6 but the cylinders are bare cast and not black.  Any information is appreciated.
Re: 4/6 Cylinder identification
« Reply #1 on: January 26, 2021, 09:37:29 AM »
The ones I have say 440/2A like Invader jugs.  No special numbers on them to indicate that they are 4/6 jugs.  The only odd one has a "3" cast into it just behind the "440/2A      3".  The humps on the intake side are the most obvious thing.
Vader19
« Reply #2 on: January 26, 2021, 09:41:43 AM »
Thanks, you would happen to have a good photo showing that difference?
Vader19
« Reply #3 on: January 26, 2021, 10:04:52 AM »
Never mind I found one.  Thanks
Vader19
« Reply #4 on: January 26, 2021, 10:37:40 AM »
Looks like someone has swapped on a set of Invader jugs, so I will likely be in the market for some 4/6 cylinders in the near future.
« Reply #5 on: January 27, 2021, 11:13:43 AM »
I have seen that swap a few times...The 4/6 cylinders like to cold seize.  They also are a 1-year only part so are more difficult to find.
« Reply #6 on: January 27, 2021, 06:46:11 PM »
Another thing to know about the 4/6 is the piston and rings.  Invader piston # for 1980 is 13001-3007 and a ring number of 13008-3001.  The 4/6 has a piston # of 13001-3011 and a ring number of 13008-3008.  The difference in the piston is the 4/6 is coated and the ring gap locating pin is positioned to put the ring gap safely along the side of the jug.  The 13001-3007 used in a 4/6 jug puts the gap on the intake bridge.  Many have run this combination but I wonder how long until the rings wear enough to catch an edge??  I have measured the rings for both and they are the same dimension's but the 4/6 ring is coated to assist with break in.  As I finish this reply I am questioning if I remember the pin location details correctly??
Vader19
« Reply #7 on: January 27, 2021, 08:09:44 PM »
Thanks for the info
