Author Topic: Temp sensor  (Read 6685 times)
Vader19
Temp sensor
« on: February 04, 2021, 08:47:50 AM »
Does anyone have any tricks for getting he temp sensor out of the the thermostat housing without wrecking it?
Thanks
Re: Temp sensor
« Reply #1 on: February 04, 2021, 08:55:42 AM »
I've never had issues getting them out.  Maybe try a brake line wrench to help avoid stripping the nut?
Re: Temp sensor
« Reply #2 on: February 04, 2021, 05:31:29 PM »
Thanks
First I try PB Blaster and a tubing wrench.  If moderate pressure on the wrench does not work I go to plan B.
Plan B:  If the temp gauge does not work, then i break the sensor bulb.  If the temp gauge is working, I use a cutting wheel on a dremel to cut the housing off of the temp probe.  If you have to cut the housing I can send you another one.
Vader19
Re: Temp sensor
« Reply #3 on: February 04, 2021, 10:26:16 PM »
Thanks
