Author Topic: 79 Drifter 440 Diagnosis Help Needed: Excited Newbie Alert  (Read 15877 times)
Re: 79 Drifter 440 Diagnosis Help Needed: Excited Newbie Alert
« Reply #15 on: February 12, 2021, 04:58:35 PM »
If I fish out the puck up tube, does it reach all the way up to the fuel cap for inspection?
All of ours  reach up to the cap.
MillerTime4242
« Reply #16 on: February 13, 2021, 05:17:06 PM »
I was inspecting the fuel filter and looked extremely dirty, and it would only fill half way while putting around at 1/3 power. I decided to replace the fuel filter and in-tank pick-up with filter on it. After doing that I started it up and ran it around the yard. Again, fuel filter will only fill 1/3 of the way. What is this a sign of? My other 440 runs full all the time. Fuel pump?
Ameritude
« Reply #17 on: February 14, 2021, 01:41:10 AM »
Sounds right.
« Reply #18 on: February 14, 2021, 10:02:05 AM »
Can you do a pressure test on your pump?
MillerTime4242
« Reply #19 on: February 14, 2021, 11:20:36 AM »
Not sure how to do that yet...
« Reply #20 on: February 14, 2021, 01:00:43 PM »
Since it will  idle, can you put a "tee" in the line to one of  the carbs and put a pressure tester on that line?  I have an old vacuum/pressure gauge from when I had to tune cars by measuring vacuum.  It is a nuisance, but tells me whether the pumps are making pressure or not.
MillerTime4242
« Reply #21 on: February 14, 2021, 02:33:23 PM »
I’m also getting a lot of fuel blowing back in air box. I ran around without air box on and fuel sprays out of carb.
MillerTime4242
« Reply #22 on: February 14, 2021, 04:09:15 PM »
Could a small tear in fuel pump diaphragm cause all my issues? Found one today.
