Author Topic: Shock for Vari Ride  (Read 52940 times)
Vader
Shock for Vari Ride
« on: September 21, 2021, 11:57:24 AM »
The Kimpex 04-269 is discontinued, and the parts distributor now lists 04-269-01 for Invader 78-81. Previously, 04-269 was listed only for 78-80. (excluded Vari Ride) The closed and open lengths are longer for this shock vs 04-269, and the eyes are 29/32 on both ends. It looks to be the same as SPI SU-04282. Is it useable with the longer lengths? If so, how do I get a rubber bushing and spacer into the eye on one end?
67 Snow Cruiser 207E
79 Invader 440
81 Invader 440
95 EXT 580 Mountain Cat
96 Wildcat 700 Touring
97 Grand Touring SE 700 triple
98 Formula III 600 triple
00 Indy Triumph 600 triple
Vader
Re: Shock for Vari Ride
« Reply #1 on: September 21, 2021, 09:23:22 PM »
Okay, just had a look at a vari ride parts diagram and I see how the shock mounts now. I was confused because now I realize that the 81 parts sled I picked up had a ski shock in the suspension and one end had the rubber bushing.
79 Invader 440
81 Invader 440
Vader
« Reply #2 on: September 21, 2021, 09:42:57 PM »
And this is the suspension from my "good" 81 Invader. The lower shock mount was moved forward on the slide rails, and the upper mount was heavily butchered, moving the upper mounting point. The limiter strap mounting point was also moved. I had assumed this was done to fit some random shock in there. The last pic is the shock that was in the parts sled vari ride.
79 Invader 440
81 Invader 440
« Reply #3 on: September 22, 2021, 10:05:05 AM »
Are you going to try the SPI SU-04282?
Vader
« Reply #4 on: September 22, 2021, 05:45:43 PM »
I guess so, seems to be the only game in town. I'll put the proper arm, install the shock in the original mounting locations, then install the suspension without springs and cycle it thru full motion to make sure the shock doesn't run out of travel.
79 Invader 440
81 Invader 440
« Reply #5 on: September 23, 2021, 07:18:40 AM »
How much longer is it?
Vader
« Reply #6 on: September 23, 2021, 07:55:36 PM »
I'm not sure, since I now know that the 2 vari rides I have don't have the original shocks so I have no reference.
One had a Kawi xxxxx-3502 ski shock and I discovered the other one that was butchered-in is a Yamaha part.
Also discovered that the SPI SU-04282 is a gas shock and the Kimpex 04-269-01 is hydraulic but they're both supposed to fit. Just have to decide whether to spend $150 or $65.
79 Invader 440
81 Invader 440
« Reply #7 on: September 24, 2021, 09:37:12 AM »
I ran the 04-269 gas shock on my 79 Invader for a few years, it was a noticeable improvement over the hydraulic shock.  IMO it was worth the extra $$$.
Vader
« Reply #8 on: September 24, 2021, 02:52:22 PM »
Ok, based on your testimony I guess I'll pry the wallet open a little wider and get the SPI.
79 Invader 440
81 Invader 440
Vader
« Reply #9 on: October 18, 2021, 11:49:17 AM »
Okay, so I got the SPI shock. It will be well past the returns window by the time I know if it fits, so I'll have to make it fit one way or another. I can see already that I will have to make some different bushings for the big end to mount on the shaft.
Does anyone know what shocks will fit on the skis?
79 Invader 440
81 Invader 440
« Reply #10 on: October 18, 2021, 02:06:45 PM »
Can you rob the bushings out of the old shock?
Vader
« Reply #11 on: October 18, 2021, 06:16:01 PM »
They're available to use, but the shock eye is a bit smaller ID than the old one, I think it's a metric size. As well, the sled came with a Yamaha shock wrangled in there, so I'm not even sure the bushings on there are the original ones. I'll have to whip something up.
79 Invader 440
81 Invader 440
« Reply #12 on: December 09, 2021, 10:18:13 AM »
Any update on the SPI shock?  Were you able to make it work?
Vader
« Reply #13 on: January 25, 2022, 02:06:44 PM »
I'm not at that point in the project yet. Still have to clean up & paint all the suspension bits and reassemble.
79 Invader 440
81 Invader 440
