Author Topic: Headlight burning out  (Read 33713 times)
Vader440
« on: November 21, 2021, 08:41:39 PM »
I'm having a problem with the headlight burning out when I rev the engine up. I'm thinking voltage regulator? Any other ideas would be appreciated. Thanks!
Re: Headlight burning out
« Reply #1 on: November 22, 2021, 07:02:33 AM »
Sounds like the voltage regulator.  Could just be a bad ground on the regulator, but for the price of the regulator, it is not worth taking chances.
Vader440
« Reply #2 on: November 23, 2021, 08:37:59 PM »
Thanks. I have one on the way.
Vader440
« Reply #3 on: December 07, 2021, 02:48:53 PM »
 I received a new voltage regulator and it didn't work. The one on the left is original equipment and on the right is the new one that is supposed to fit Kawasaki's but it doesn't. The part number was 01-154-33. Just an FYI.
« Reply #4 on: December 07, 2021, 06:39:15 PM »
can you show a photo of the face of the plugs?
Vader440
« Reply #5 on: December 07, 2021, 06:54:28 PM »
It almost looks like an Arctic Cat regulator, but I double checked, and it's supposed to be for Kawasaki.
« Reply #6 on: December 07, 2021, 07:32:24 PM »
So the plug looks correct, but the wires do not seem to enter the same and when you plug it in it does not work correctly?
This is the one that I have been buying:
https://www.denniskirk.com/kimpex/voltage-regulator-for-manual-start-engines-01-154-33.p2157.prd/2157.sku
Vader440
« Reply #7 on: December 09, 2021, 01:39:50 AM »
That's the exact one I ordered, but as you said it is not wired the same. Put one on from another Kawasaki and everything worked just fine. I'm at a loss.
