Author Topic: External Ignition Coil  (Read 23286 times)
« on: December 22, 2021, 06:54:07 AM »
Good morning.  I am checking to see if anyone knows a source for new Intruder/Invader external ignition coils?
The coil on our pink sled was dead and I have gone searching through my usual sources and am either coming up with no listing or no stock.
Are others seeing this same thing?
ArcticInvader
Re: External Ignition Coil
« Reply #1 on: December 23, 2021, 06:26:42 AM »
Hi Mark, I have lots of cars Mark if you need one
2010 Arctic Cat Z1 turbo
1996 ZRT  600
1996 ZRT 800
1995 Cougar 550
Projects : 3x 1980 LTD 4/6 all being restored
               2x 1978 Invader 440
                1x  1978 Invader 340
« Reply #2 on: December 23, 2021, 06:30:33 AM »
 Like many things during this pandemic they seem to be non existent.
  There are some options
 I know of a few that have successfully used a Polaris Indy CDI/Coil unit on these engines.
« Reply #3 on: December 24, 2021, 10:46:43 AM »
I have a Polaris cdi that I will be installing on my Invader.  A reputable engine builder recommended it for a better timing curve.  It requires moving the stock stator plate significantly.
« Reply #4 on: December 25, 2021, 09:31:10 AM »
It will be interesting to hear how that works out.
« Reply #5 on: December 25, 2021, 10:43:54 AM »
 A Polaris CDI unit gives a similar timing curve to a 82-84 Liquifire or a 4/6.
« Reply #6 on: December 26, 2021, 08:32:51 AM »
He built a standard Invader motor with Polaris CDI, custom heads, porting, and 4/6 pipes that ran mid 80s HP on the dyno with a nice broad power curve.
« Reply #7 on: December 26, 2021, 08:35:18 AM »
Yeah, should be similar to the Liquifire, but the 4/6 uses an older cdi similar to the old arctic cat.  Many swap them out for Invader heads and ignition for an improvement.
« Reply #8 on: February 22, 2022, 09:37:34 AM »
I now have an external ignition coil on "backorder."  I am told that delivery will be in March.  We will see how that works out.
« Reply #9 on: February 22, 2022, 01:18:36 PM »
I'm sure I have a good used coil if you need one.
« Reply #10 on: July 22, 2022, 06:28:11 PM »
Coils finally arrived!
« Reply #11 on: July 23, 2022, 03:43:03 PM »
That took a while!
« Reply #12 on: July 23, 2022, 09:51:23 PM »
I think some of the 2 stroke Kawasaki motorcycles used these coils to
« Reply #13 on: July 24, 2022, 07:38:44 PM »
That took a while!
Better late than never.
