Author Topic: Track Vibration  (Read 30115 times)
Re: Track Vibration
« Reply #15 on: March 30, 2022, 06:45:24 AM »
While hardly pristine, I opted for one of the tracks that had all of its track clips.  It is now freshly studded and as soon as I can pick up a new bearing it should be going back in the sled.  The skid has been checked out and I am replacing the rear upper suspension mounting shaft. The shaft itself does not look bad, however the shape of the track loop is odd so I pulled another one.  So, with a new drive shaft, new suspension shaft, new bearing and new track, if the problem repeats itself i will at least know it is none of those things.
Re: Track Vibration
« Reply #16 on: March 30, 2022, 12:43:58 PM »
That should grip pretty good.
Re: Track Vibration
« Reply #17 on: April 01, 2022, 06:35:35 PM »
Picked up the new bearing tonight on the way home from my day job.  So new bearing, replacement drive shaft (used), replacement track (used), replacement rear mounting shaft (used) and a few other odds and ends have been installed so the sled is ready to test.  Only problem, I am going to need to wait until next season.  So this pair will be going into the machine shed tomorrow.
Re: Track Vibration
« Reply #18 on: April 02, 2022, 04:46:38 PM »
Sleds are away for the season and quietly snoozing. I couldn't help sharing the photo of the "pastural scene"
Re: Track Vibration
« Reply #19 on: April 02, 2022, 08:00:21 PM »
Well done!!  I put the 82 Intruder in it's summer resting spot today.
