Author Topic: 340 Invader (stumped)  (Read 89274 times)
Vader440
« on: November 23, 2022, 06:39:30 PM »
340 Invader 120 psi on both cylinders good spark both cylinders carbs are clean. Will start for a second or two and then nothing. Ran fine last season. Any ideas would be appreciated.
Re: 340 Invader (stumped)
« Reply #1 on: November 24, 2022, 07:17:14 AM »
Good morning and Happy Thanksgiving.  120 sounds on the low side but should run.  If all is well with the carbs, have you tried removing the exhaust to see if there is an exhaust obstruction?  Could be an intake obstruction also, but less likely.
Vader440
« Reply #2 on: November 24, 2022, 01:16:23 PM »
I haven't tried removing the exhaust pipe. That's about the only thing left to try. Thank you! Happy Thanksgiving!
« Reply #3 on: November 24, 2022, 08:20:56 PM »
Mufflers make great mouse nests.
Vader440
« Reply #4 on: November 24, 2022, 08:53:10 PM »
I sure hope that's what it is because I'm at a total loss. Thanks!
Ameritude
« Reply #5 on: November 28, 2022, 01:10:42 PM »
Pulled this out of an airbox about a week ago 😳
« Reply #6 on: November 28, 2022, 05:57:52 PM »
Mice have no respect.
« Reply #7 on: November 30, 2022, 09:08:31 AM »
No respect!
Vader440
« Reply #8 on: December 01, 2022, 02:54:53 PM »
Still no go. Compression good, fresh fuel and carbs are clean, spark good, pulled off exhaust pipe. It still only pops a little but will not start. Can you have spark and the CDI still be bad? Flywheel key? Very frustrating. Walking away from it for now. Maybe try again sometime.
Ameritude
« Reply #9 on: December 01, 2022, 06:41:01 PM »
It's definitely timing of some sort, check the flywheel key, it's rare, but they can sheer. Also check that the bolts that hold the stator on are tight, you can see that they are, by just looking through the holes on the magneto screwdriver. Tightness with a skrewdriver.
Ameritude
« Reply #10 on: December 01, 2022, 07:03:03 PM »
That was supposed to say check tightness with a screwdriver, dont loosen the skrews, just see if they are already loose.
« Reply #11 on: December 02, 2022, 09:40:16 AM »
How is the fuel pump and the lines going to and from it??  Is the primer still hooked up??  I have seen them leaking air and causing this very thing.  Try putting a little gas down the plug holes and "if" it starts watch all the fuel lines for moving air bubbles.  Good luck!!
« Reply #12 on: December 03, 2022, 08:06:00 AM »
Yes, this is important.  I had an Intruder that frustrated me a few years ago.  I finally found the key had slipped out while putting on the flywheel.  It was stuck to one of the magnets.  Never would have found the problem without pulling the flywheel.
Vader440
« Reply #13 on: December 03, 2022, 01:52:45 PM »
I plugged off the primer tubes just to make sure they weren't leaking, still no go. I will try to pull flywheel next. Thanks for the info.
Vader440
« Reply #14 on: December 03, 2022, 01:57:50 PM »
I'll take a look. Thank you!
