Author Topic: Leaky Skidoo Fuel Tank  (Read 892 times)
« on: May 08, 2023, 08:45:50 AM »
Good morning.  We have a 1989 Skidoo in the shop.  One of the projects was to get rid of dried out fuel lines and eliminate fuel leaks.  We got everything taken care of and then found that the rubber grommet in the fuel tank was leaking fuel.
Has anyone had any experience with these? I am hoping that there is a simple solution to this problem.
Re: Leaky Skidoo Fuel Tank
« Reply #1 on: May 08, 2023, 09:14:17 AM »
I have not had to deal with that.
Ameritude
« Reply #2 on: May 08, 2023, 03:02:38 PM »
from the picture it looks similar to the generic rubber tank pickup that I see in a lot of applications. if so, here's a link to the ones that I've used from whalbros
https://wahlracing.com/product/fuel-tank-fitting-w-grommet-straight-metal-3-16-1-4/
they have a couple different options
« Reply #3 on: May 09, 2023, 09:48:35 AM »
Thank you. Looks good.
Ameritude
« Reply #4 on: May 09, 2023, 03:36:19 PM »
You bet, I have repaired some in the past with gasket maker, but its temporary.
« Reply #5 on: May 10, 2023, 07:57:10 AM »
That was a good find!
