Author Topic: Clutch puller?  (Read 19467 times)
swedefire
Clutch puller?
« on: January 20, 2013, 12:16:11 PM »
Does anyone know what threads the primary clutch has, I think Ill go with the water/oil trick..?
Thanks!
The Great Jashu
Re: Clutch puller?
« Reply #1 on: January 20, 2013, 12:30:44 PM »
The Kawasaki clutch puller is the only one that will work. The are available for about $15 from Dennis Kirk or Shadetree. Cheap investment.
Invader440
    • Curt's Snowmobiling Page
Re: Clutch puller?
« Reply #2 on: January 20, 2013, 03:05:27 PM »
Invader/Intruder/Interceptor - Kawasaki clutch tool.  All others use the Arctic Cat hex clutch tool except the 81 Drifter which had it's own puller.
Drifter
Re: Clutch puller?
« Reply #3 on: January 20, 2013, 08:56:16 PM »
I brought mine to the local Brafasco and the bolt to try the water trick was $24.00 and they didn't stock them. The proper clutch puller is less than $20.00.  Needless to say the proper ones on its way.
Drifter
Re: Clutch puller?
« Reply #4 on: January 22, 2013, 05:04:08 PM »
My Brafasco dealer checked the thread with a tap and said it was M14 x 1.5 pitch but I was thinking later that if it was an Arctic cat clutch than why would it be metric?  I left Release All in the hole for the clutch for a few days and it came off with little effort. ;)
Invader440
Re: Clutch puller?
« Reply #5 on: January 22, 2013, 08:39:42 PM »
Hex clutch puller would have 9/16-18 threads.
swedefire
Re: Clutch puller?
« Reply #6 on: January 23, 2013, 12:39:45 PM »
To answer my own question...the threads on the kawa made clutch is M18 x1,5mm i used the water trick and it is just super easy...  Now mowing on to engine disassembly...
Thanks!
