Author Topic: Drifter questions  (Read 32677 times)
0 Members and 5 Guests are viewing this topic.
Re: Drifter questions
« Reply #15 on: February 02, 2013, 03:45:02 AM »
 GLad you got it going.
 I would plan on plulling the motor to do crank seals.
 They are a fun sled !!!
 You should have lots of entertainment with it.
81drifter
« Reply #16 on: February 02, 2013, 05:00:49 AM »
Yea. Do it this spring most likely. Get the most fun out as possible. Runs really nice even wide open and goes through powder good.
« Reply #17 on: February 02, 2013, 08:35:17 AM »
 The Drifters are the best powder machine I have ever riden.
81drifter
« Reply #18 on: February 02, 2013, 05:01:26 PM »
Wouldn't start today in 5* weather. Wanted to at times but didn't. Ground was disconnected so we redid that. Flooded out by time I had to go. Any ideas? And primer isn't working today?
« Reply #19 on: February 02, 2013, 05:08:20 PM »
 Your primer would go in and out just not pump fuel?
 if so  I would suspect an air leak ion your fuel line. This would let fuel go back to the tank.
81drifter
« Reply #20 on: February 02, 2013, 07:21:08 PM »
Yes. Will look for leak. Old hoses still. Except from pump onward. Was working fine then stopped. Yesterday after she warmed up it was 1 pull. Then ran out of gasit seams when I returned to try today
81drifter
« Reply #21 on: February 03, 2013, 09:03:52 PM »
Got it going.
« Reply #22 on: February 04, 2013, 04:24:16 AM »
 What did you do to get it running?
81drifter
« Reply #23 on: February 04, 2013, 11:38:30 AM »
Had more gunk in main jet that wasn't letting needle seat all the way causing it to flood. And heads were loose and on wrong cylinder and had low compression because of it.  Still takes about 4-7 pulls to start cold but after warm just one.
