Author Topic: Low fuel in lines  (Read 13175 times)
doug440
Low fuel in lines
« on: January 25, 2013, 06:54:52 PM »
took the tank off and was going to replace it, but the tank was different hook ups. the fuel wouldn't flow right, the line from the tank to the Pump(?) barely has fuel in it and air pockets. are the vacuum? ran fine before i messed with it now cant figure it out. any suggestioins? thanks
Re: Low fuel in lines
« Reply #1 on: January 25, 2013, 09:27:55 PM »
sounds like the pickup tube inside the tank has holes in it or is missing the weight on the end.
doug440
« Reply #2 on: January 26, 2013, 08:37:44 AM »
will check that. thanks
