Author Topic: 1980 4/6 porting..How much will i gain?...is it worth it?  (Read 26873 times)
Paul John Vanderweerd
« on: January 28, 2013, 03:04:26 PM »
I am currently deciding whether or not I should do the Aaen trail porting on the 4/6 engine I am running in my sled. It needs to be re-plated since I have low compression. Currently running with 38mm carbs, and Aaen pipes. To port cylinders and machines head will cost about $500 I'm told. Anyone ported a 4/6?  What percent gain will I notice?
Re: 1980 4/6 porting..How much will i gain?...is it worth it?
« Reply #1 on: January 29, 2013, 12:36:02 AM »
I would guess not much.. Kawasaki did their homework on the 4/6's and they go pretty darn good stock.
« Reply #2 on: January 29, 2013, 08:05:20 AM »
You won't get much more from the 4/6 jugs unless you want a full mod race motor, not a trail freindly sled.  You need to talk to Sprocket about the porting.
