Author Topic: How do you make engine parts look like new?  (Read 22244 times)
« on: February 28, 2013, 05:22:32 PM »
Is there an easy way to make engine parts look like new?  I have not found anything in my shop that will clean up aluminum to make it even look close to a new engine.   I would appreciate insights on this topic.
Re: How do you make engine parts look like new?
« Reply #1 on: February 28, 2013, 05:36:52 PM »
 I have not done it (yet) but I have seen engine parts that were sandblasted and parts that were soda blasted. Both looked really good.
Soda blasting is easier on the engine parts.
 I bought (but don't have it set up yet) a blasting cabinet that I intend to set up as a soda blasting cabinet.
« Reply #2 on: February 28, 2013, 06:31:12 PM »
I have sandblasted engine parts with excellent results.  I have seen bead blasted parts, they look good, but I prefer the sandblasting.
« Reply #3 on: February 28, 2013, 07:07:52 PM »
Lloyd, is that baking soda or Coca Cola?
gavinvader
« Reply #4 on: February 28, 2013, 07:27:43 PM »
ive had good luck witha wire wheel
JDmatt
« Reply #5 on: February 28, 2013, 07:46:23 PM »
Baking soda or walnut blasting.  Sandblasting can pit aluminum pretty bad.
Matt
« Reply #6 on: February 28, 2013, 08:06:38 PM »
This is my engine that I sandblasted.  I sandblasted the exterior of each part prior to assembly.  While I can't vouch for all sandblasters and operators, but I experienced zero pitting.
« Reply #7 on: February 28, 2013, 10:24:31 PM »
Mark
 Baking soda. Much easier on parts that sand.
« Reply #8 on: March 01, 2013, 05:45:34 AM »
I would be very satisfied with an engine that looked like that!
« Reply #9 on: March 01, 2013, 07:21:05 AM »
A fine bead works good.  I've not yet tried the soda but hear it works good.
« Reply #10 on: March 01, 2013, 03:43:49 PM »
I have tried both beads and soda results were similar but the beads did the job faster.
JDmatt
« Reply #11 on: March 01, 2013, 07:06:45 PM »
Maybe pitting is the wrong word, but your cylinders look pretty roughed up from the sand.  You would end up with a smoother, more gloss finish with something less abrasive.
Matt
« Reply #12 on: March 02, 2013, 05:34:22 PM »
Aaaah... sand blasting.   Just when you think you've washed and scrubbed enough...  somehow that sand can get in places that you wouldn't believe!!!  My opinion....  sand is best left for parts other than engine parts, or the beach.
hj1515
« Reply #13 on: April 07, 2013, 12:27:40 PM »
i just redid a 1989 Polaris INDY 500 and I had teh top end sand blasted and teh bottom end bead blasted. Only reason for the 2 was that I took the top end off and kept it to just clean up and teh bottom end i sent whole to the crank shop where they redid the crank and blasted the parts etc. There was no difference in the bottom or top end with the different methods. Like the previous post said too... maybe it depends on the operator but my engione had no pitting or issues from teh blasting it looked better than factory original! :-)
