Author Topic: replacement rad cap and thermostat.  (Read 16900 times)
bryan_damone
« on: March 01, 2013, 07:27:43 AM »
Does anyone have any brands and part numbers for a suitable rad cap and thermostat for an Invader.
Thanks
« Last Edit: March 01, 2013, 09:19:26 AM by bryan_damone »
Re: replacment rad cap and thermostat.
« Reply #1 on: March 01, 2013, 07:54:39 AM »
I have taken my original radiator cap into my local NAPA autoparts store and matched it up.  I couldn't get the exact psi rated cap, so I went with 1 psi higher.
I have never heard of a replacement thermostat, I have never seen, or heard of one go bad either...  Did you have one fail?  I'm sure I have a good used one if needed.
bryan_damone
Re: replacement rad cap and thermostat.
« Reply #2 on: March 01, 2013, 09:19:01 AM »
Do the thermostats ever fail open. Seems like I have a hard time warming up. Temp gauge only begins climbing if you leave it idling and/or drive around slowly. Soon as I hit some snow, the temp drops immediately. I thought the thermostat would be able to regulate the engine temps a little better.  If this is normal, let me know. Of course I will pull it out and take a closer look when I have the chance.
I just saw that rad caps and thermostat are on sale at Parts Source in Ontario so I thought I would grab some spares.
« Reply #3 on: March 01, 2013, 09:43:16 AM »
We have the NAPA part number at home for a 13 psi replacement cap.  Our invader runs cold when there is plenty of loose snow to keep the tunnel cool and runs hot when snow is hard packed.
« Reply #4 on: March 01, 2013, 10:18:02 AM »
My 81' Invader acts the same way.  My 79' runs a little warmer because of the smaller heat exchanger.
bryan_damone
« Reply #5 on: March 01, 2013, 12:21:37 PM »
Well if all is normal, I am happy.
« Reply #6 on: March 01, 2013, 05:13:33 PM »
NAPA Part No.  703-1445
