Author Topic: Restoration of #378  (Read 48460 times)
Winter Thunder
Re: Restoration of #378
« Reply #15 on: July 10, 2015, 05:04:33 PM »
Nice!!  On the piston, did they move the ring end gap locating pin and where does the side hole line up??
The ring gap pin has not been relocated.
The side holes are located 13mm from the top edge of the dome to the center of the hole.  Hole diameter is 5.95mm.
Winter Thunder
« Reply #16 on: July 10, 2015, 05:06:35 PM »
Ignition components cleaned up like new.
« Reply #17 on: July 11, 2015, 07:01:12 AM »
The only thing they did to the piston was bore the pin hole out.  Since the cylinder in nikasil they can use the standard jet ski rings ( cast iron bore ).  I will be in your neck of the woods on the 26th to bust some birds.
Winter Thunder
« Reply #18 on: July 13, 2015, 06:35:36 PM »
Seats done.
« Reply #19 on: July 14, 2015, 06:46:33 AM »
Looks nice,  who did it?
Winter Thunder
« Reply #20 on: July 21, 2015, 09:35:42 PM »
It's original.  Input the tail ligbt and emblem on from the other seat.
Winter Thunder
« Reply #21 on: July 21, 2015, 09:41:42 PM »
Winter Thunder
« Reply #22 on: July 21, 2015, 09:49:57 PM »
Belly pan cleaned up well.  Didn't find any cracks in it either.
sgtobias
« Reply #23 on: December 17, 2016, 10:01:11 AM »
Just wondering what you used to clean and restore your belly pan?
Greg
