Author Topic: reinstaling cluch  (Read 11592 times)
menger69
reinstaling cluch
« on: August 13, 2013, 05:41:32 AM »
  hi should anti seize be used on the shaft and what should it be torqued at thanks
Re: reinstaling cluch
« Reply #1 on: August 13, 2013, 06:13:36 AM »
  Yes, use anti seize and 70 ft/lbs.  Most importantly, check for burrs, rust, ect on the end of the crankshaft taper.  Most people overlook this, but all it takes is a small nick "raised metal" to hang the primary up upon removal.  Needs to be smooth!  Emery cloth and a finger is all it takes.
« Reply #2 on: August 13, 2013, 08:20:21 AM »
I disagree.  I NEVER use anything on the taper.  It is a friction fit, and anti seize will reduce friction.  The manual states:  "Tapers must be clean and dry."
I do use a little on the threads of the clutch bolt.
« Reply #3 on: August 13, 2013, 12:04:56 PM »
re torgue after a short ride to prevent split washer problems
AdrenalineJunky
« Reply #4 on: August 17, 2013, 11:49:10 AM »
I clean clutch bore and crank taper with an emery cloth, then I wipe 'em with wd-40, and install.  Grease or heavy lube may prevent taper from fully seating resulting in a possible flying clutch assy!
