Author Topic: Invader rear suspension wheel size  (Read 10457 times)
nickw
« on: October 31, 2013, 08:23:23 AM »
Pulled the rear skid out on my '80 invader project last night.  Looks like almost all the bearings are shot on all the wheels.  Can anyone point me in a good direction for finding replacements?  What size should I be looking for?  Also noticed it has the three wheels on the back but a rubber track.  Do I need to convert to a 4 wheel setup?
Re: Invader rear suspension wheel size
« Reply #1 on: November 01, 2013, 01:57:18 AM »
The 4 wheel setup was used on the suspensions that were changed out from the original tracks that tended to throw cleats out the back. If you use the 3 wheel setup, you may not be able to get the track tightened up enough. The 4 wheel setup used slightly larger wheels.
nickw
« Reply #2 on: December 16, 2013, 02:03:08 PM »
Well got the rear ski almost back together.  Ended up reusing all the wheels and replacing just the bearings and inserts.
All the wheels use a 6205-2rs bearing and 3/4" inserts.
Bearing
https://www.denniskirk.com/parts-unlimited/25x52x15mm-bearing.p1251.prd/1251.sku
Inserts
https://www.denniskirk.com/parts-unlimited/small-flange-idler-wheel-inserts.p04222.prd/04222.sku
https://www.denniskirk.com/kimpex/large-idler-wheel-inserts.p04223.prd/04223.sku
