Author Topic: Invader clutch disassembly  (Read 11097 times)
« on: December 28, 2013, 04:17:09 PM »
After many years of driving these sleds I need to fix a clutch.  To do that I need to take it completely apart but it is putting up a fight.  The cover came off easy but the spider seems to want to stay right where it is.  Any help would be good before I bust something.  This is the 81 I had at Braapfest last year and The clutch went out of balance. I limped her back to the cabin and shut her off.  Turned out a guide shoe had come apart.  I do have a clutch off a 4/6 I could put on but I prefer a lower ingagement for my slow poke style of trail riding.  I could change the weight but I wish to leave that clutch as is.
Re: Invader clutch disassembly
« Reply #1 on: December 28, 2013, 05:32:30 PM »
It put up a pretty good fight but it turned out to be plain old rust. This is my first chance to play with a sled since last March.
invader87
« Reply #2 on: December 28, 2013, 10:16:09 PM »
good that you got it apart. i had to cut the sleeve off the last one i had apart.
« Reply #3 on: December 29, 2013, 12:00:20 PM »
I put a little PB Blaster on the inside of the sleave and a little heat until the blaster started to bubble.  Clamped it up in a vise and tapped on the webbing on the engine side of the clutch.  It still protested a little but it came off.  I have the steel parts in rust remover and will be re assembling it later.
