Author Topic: first Kawi sled  (Read 33509 times)
Re: first Kawi sled
« Reply #15 on: February 01, 2014, 08:21:31 AM »
imo mag seal....at idle [on pto cyl] pull up on the choke cable right at the suspect carb/cyl,applying verry light momentary choke, a rpm reaction up or down indicates a fuel/seal problem.over the years i drifted a lot of seals in on kaws, kohlers,etc,but as the motor is out to do the mag side its way better to just split the case on a vader/truder because of the pto seal.    imo
Re: first Kawi sled
« Reply #16 on: February 01, 2014, 08:57:58 AM »
Crank seals do not affect compression. The only way to properly do crank seals is to split the bottom case. If you don't, you will shear off the rib on the outside of the seal and it will leak. Also gives you a chance to clean off the case mating surfaces and seal them as they could leak there as well.
You do not have to remove the cylinders or the top end when doing crank seals.
as you described, it could be a coil issue. Been there!!
Re: first Kawi sled
« Reply #17 on: February 01, 2014, 09:03:10 AM »
A bad crack seal shouldn't affect compression...
Try switching plug wires from side to side and see if the side that's firing changes.
Cpt. Kawi
Re: first Kawi sled
« Reply #18 on: February 01, 2014, 03:40:50 PM »
A compression test only tells the condition of the rings and cylinder. I've pretty much eliminated spark and fuel (switched plugs and carbs) problem still exists on the mag side.
Guess I'm just going to run it like I stole it till my gasket kit gets here.
Snowmobiles:
81' invader 440
Motorcycles:
64' kawasaki B8t
71' Mt1 Parnell Jones #641 & #14276
72' ke 175
75' H1 500 streetfighter
77' kz1000
79' kz1000
85' ninja 900r
09' concours 14
