Author Topic: Drive Axle  (Read 8432 times)
79Intruder
  • Stripping down 79 Intruder
Drive Axle
« on: October 25, 2014, 08:01:37 AM »
Hey guys, Looking or a little help? I have a 1979 Intruder 440 I trying to get the Drive Axle off, The book I have is not giving a enough info. Any one got a simple way of removing it? Any help greatly appreciated. Thanks.
Re: Drive Axle
« Reply #1 on: October 26, 2014, 10:00:49 AM »
Pull the parts off each end of the shaft so it slides both ways a little.  It will go far enough that one end will drop down so you can remove it.  Not real simple but not that hard, just takes a little time.
Good Luck!
Re: Drive Axle
« Reply #2 on: October 27, 2014, 12:25:05 PM »
with sprocket and left bearing cup removed it should 'drift 'left if tapped.must clear track drivers also.
